June 11, 2004, 15:12 |
Fluent adaptation procedure
hello, i'm trying to refine one of my meshes generated using Gambit. i want to use the adaptation procedure in fluent but it seems there is so many criteria to be used or setup. i am using a hybrid mesh for a two element airfoil and the mesh quatlity or transfer of cells is not that good espacially between the main wing and flap. i tried gambit, i was able to refine it for a certain limit but i still need more refinement. i was wondering if somebody has a past experience with the subject or any comments.. regards
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 21:23 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 03:44 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 17:41 |
Adaptation failing in // Fluent case? | Riaan | FLUENT | 0 | February 3, 2006 15:57 |
