Hydraulic Diameter or Length Scale
Old   June 11, 2004, 10:43
Default Hydraulic Diameter or Length Scale
Bob
I am simulating a 3D gas turbine combustor. What would be the best to use length scale or hydraulic diameter. My first run will be non-reacting. Also, if I use length scale would I choose the height or the width of the outlet. Or maybe it would be better to use the viscosity ratio. Most of the tutorials are 2D and with 3D this issue has always been confusing to me. Any help will be appreciated.
Old   June 11, 2004, 10:49
Default Re: Hydraulic Diameter or Length Scale
Tom
I would use Hydraulic Diameter and take the diameter as that of the outlet/inlet.
Old   June 11, 2004, 11:56
Bob
Now, would I use the height of the outlet or the length?
Old   June 17, 2004, 10:13
martin
In Fluent there is a simple relation between length scale and characteristic dimension (diameter): l=0.07*L
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 08:22
hydraulic diameter in 2d ahsan FLUENT 2 August 28, 2009 16:22
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 11:58
Length Scale vs. Hydraulic Diameter? Will FLUENT 1 April 13, 2004 07:09
