Boundary condition for interface
Old   June 8, 2004, 12:49
Default Boundary condition for interface
zhou
There are two regions that is next to each other and is connected by the interface. There are mass and heat exchange between this interface (actually, this interface belongs to "interior" in fluent). I want to set a fixed gradient of species mass fraction at this interface as i want. However, it seems to me that FLUENT does not have this function for user at "boundary condition" panel. So how to solve this kind of problem in FLUENT? Thanks.
Old   June 8, 2004, 13:09
Default Re: Boundary condition for interface
Ari
I think it's possible by defining this interface as a wall zone and by using a UDF for the mass fraction.
Good luck!!!
Ari
Old   June 8, 2004, 13:22
zhou
Hi, ari I am still confused. There are mass and heat transfer between the interface. If i change it to wall, the only choice of boundary condition at wall for gradient of species mass fraction is "zero diffusive flux" and i still can not set a fixed gradient of species mass fraction as i want. In addition, how i keep the mass and heat transfer as it does at interface ?
Old   June 8, 2004, 16:12
Ari
Before you have to define an UDF, for example with the macro DEFINE_SOURCE() (see UDF manual) and then the new option ("user defined") should be available. I'm sorry, but I have not understood.
Ari
Old   June 8, 2004, 16:14
Ari
Before you have to define an UDF, for example with the macro DEFINE_SOURCE() (see UDF manual) and then the new option ("user defined") should be available. I'm sorry, but I have not understood the last question.
Ari
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 03:37
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 06:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
