Species diffusion coefficient
Old   June 7, 2004, 22:06
Default Species diffusion coefficient
iceabc
I defined species mass diffusion coefficient by dilute approximation and then i want to use diffusion coefficient at some UDF. I found there is a macro "C_DIFF_L(c,t,i,j)" used for diffusion coefficient in FLUENT. I know "i" and "j" meaning. However, the diffusion coefficient defined by dilute approximation is based on species "i" diffusion at mixture and not based on that species "i" diffuse in species "j". So how to use this macro to obtain the species diffusion coefficient defined by dilute approximation and how to set "i,j" at this macro? Thanks.
Old   June 10, 2004, 11:04
Default Re: Species diffusion coefficient
D Harvey
There is a post on the fluent website on how to specify your own diffusivity model. In it you are shown how to calculate j1,j2 for a binary model from the value of i that is passed in the define diffusivity macro. The dilute model is species i diffusing into background species not each individual species. The C_DIFF_L(c,t,i,j) is a binary value and is used to form D[i[m]]. Check out the fluent site and see if that can't give you any ideas.
DH
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
binary diffusion coefficient / kevin FLUENT 3 July 1, 2012 14:07
Questions on Species Mass diffusion coefficient Eddy FLUENT 1 March 11, 2008 12:06
Who ever wrote the mass diffusion coefficient ?? kevin FLUENT 0 April 30, 2002 10:37
Who can write the binary diffusion coefficient ?? Hsin-Ping FLUENT 1 April 15, 2002 03:22
