swirl flow
Old   June 7, 2004, 15:09
Default swirl flow
rvndr
hi friends
how to model a swirl flow.....in a 2D combustor with velocity inlet and pressure outlet as a boundary conditions.I tried by selecting
define---models---solvers----axisymmetric swirl flow.
Is this is the correct way.
if this is the correct way then how to calculate
1.Axial component of flow direction 2.Radial component of flow direction.
I know only inlet air velocity and swirl number for example (velocity 1m/sec and swirl number 0.3). Ofcourse mass flow also I know.
If there is any literature plz do help me
Thanks in advance
regards rvndr
Old   June 8, 2004, 04:56
Default Re: swirl flow
Dr. amit_at_msu
ihave some experimental results of swirl flow when modeled same in fluyent i am not getting required pressure drop. can you help me.
Old   June 8, 2004, 06:27
Tom
What discretization scheme and turbulence model are you using?
Old   June 8, 2004, 13:35
gaurav
Hello Amit, I am also modeling gas turbine combustor with all of the flow features using fluent. May be we can share the information/results for better undrestanding of flow physics ..
Regards, Gaurav
Old   June 9, 2004, 03:13
Dr. amit_at_msu
Dear Tom If you can allow me to attach me on your mail the brief details i can describe the same. thank you
Old   August 4, 2009, 03:41
Question swirl flow.....
siva kumar
shshiva17 is on a distinguished road
Hi frns,,,,
Am also doing seirl flow in combustor model but i sonno how to calculate the components like axial,,circumferential i.e,,,,,swirl velocity,,,,,,i know my swirl no and velocity,,,,,if u know any calculation theory regarding this plzzz help me?
my email id :shshiva17@gmail.com
shshiva17 is offline   Reply With Quote
Old   December 2, 2010, 04:09
Default I also have this problem
Saeed
saeedbh85 is on a distinguished road
hi friends
Thanks in advance
saeedbh85 is offline   Reply With Quote
Old   December 3, 2010, 04:10
Exclamation need help for k-e turbulence model,RNG
naresh
nareshnkk is on a distinguished road
PROPELLER-rotation clockwise.
domain:::::inlet was considered of distance of 3D from mid of chord of root
section and outlet is considerd upto a dist of 4D from axis of hub.
at J=O.45, N=783.6RPM, Va = 8.23m/s
It is steady flow, turbulent model- RNG K-E.
domain with dia 4d, length 7d, d=1.4m.
material- water_liquid.
nareshnkk is offline   Reply With Quote
Old   May 28, 2012, 06:45
juzer_700 is on a distinguished road
Originally Posted by shshiva17 View Post
Hi frns,,,,
Hey Im new to CFD, and im simulating combustion chamber of a gas turbine. Im using 2D axisymmetric. I have mention the swirl number and inlet velocity. How do I calculate the swirl velocity??? Please help. Im new to this. Any help will be appreciated. Please.
my email ID is: rangwala.juzer@gmail.com
juzer_700 is offline   Reply With Quote
Old   May 28, 2012, 06:46
Originally Posted by Dr. amit_at_msu
;113095
Hey, I'm new to CFD, and im simulating combustion chamber of a gas turbine. Im using 2D axisymmetric. I have mention the swirl number and inlet velocity. How do I calculate the swirl velocity??? Please help. Im new to this. Any help will be appreciated. Please. Any calculations or reference where I can find any information??
Old   May 30, 2012, 03:53
James Willie
jwillie2000 is on a distinguished road
Hi, do you have a copy of this book: gas turbine combustion by arthur lefebvre? I think it would be helpful to you.
jwillie2000 is offline   Reply With Quote
swirl flow in FolwWork Simulation linsir0825 FloEFD, FloWorks & FloTHERM 1 June 7, 2011 06:02
Quantifying Swirl Ianto Main CFD Forum 0 April 27, 2009 11:54
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 10:49
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
HElP!!!! Swirl flow in tube khairy FLUENT 0 August 4, 2005 19:04
