b.c. definition
Old   June 5, 2004, 11:00
Default b.c. definition
john
I'm simulating only heat transfer in a 2-D SOLID rectangular domain (unsteady problem). The heat conduction coefficient and heat source in the whole domain is temperature dependent.
The boundary conditions are const temperature on the right and left sides - no problem with that. on the upper and lower side the temperature is X coordinate dependent...
I've never used UDF in fluent but I think this is the right case to do so
Anyone know where can I find examples or UDF's for those cases ?? i.e. conduction coefficient and heat source whice are temperature dependent and temperature variation BC on walls
I didn't find much help in the UDF manual
Regards John
BTW: I also have an IC which is x dependent
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 06:19
Confusion between 'non-slip' and 'slip' B.C jinwon park Main CFD Forum 7 March 6, 2008 05:56
Urgent! Help on UDF to set B.C. of 3rd type Ray Hong FLUENT 0 December 28, 2005 20:35
How to set B.C. of the 2nd or 3rd type in UDS? Ray Hong FLUENT 0 December 28, 2005 07:03
