flow in a skinny tube
Old   June 4, 2004, 14:36
Default flow in a skinny tube
Rookie
I got a nasty problem needs your kind help -- I am trying to simulate flow in a very skinny tube. The length of the tube to the diameter of the tube is around 5000. It is virtually impossible to draw such a domain for computational purpose. Do you have any good ideas to handle with this problem?
Thank you all in advance!
Rookie
Old   June 10, 2004, 19:20
Default Re: flow in a skinny tube
Tim P.
Is it just a tube? Have you considered a periodic flow? I haven't used one but I know they are used for repetitive instances. Section 8.3 of the FLUENT 6.0 manual might help.
Cheers, Tim.
concentric/tube in tube counter flow HX ask123 FLUENT 0 May 24, 2010 07:41
Flow Through Bend tube of circular c/s applemango FLUENT 0 March 8, 2010 05:52
fluid flow problem in 3D tube gurunarayana ravi FLUENT 0 September 9, 2007 19:55
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
