meshing filter paper
Old   May 31, 2004, 01:41
Default meshing filter paper
Thiyagarajan
hi all, i am modelling an airfilter with gambit.the surface area of filter is 40 sq.m.and thickness is .0006m.when i meshed, i gave spacing of 0.006 to avoid high aspect ratio.but that took verylong time and i couldn't mesh. can i get any method to mesh without reducing the overall area.even with reduced area i couldn't mesh. thanks for any suggestions. regards Thiyaga.
Old   May 31, 2004, 14:10
Default Re: meshing filter paper
Tim P.
I would initially suggest dividing up the volume and meshing each smaller area, and combining them all using the interface BC. But I don't think that interface works when the interfaces are alligned with the flow.
Could you divide up your surface area into many virtual areas then try meshing each smaller virtual area on it's own?
Also, would a porous jump BC work for your case instead? You could always just set your porous medium thickness to 0.0006 m.
Just some suggestions, Tim.
Old   May 31, 2004, 15:12
George
1. What is the purpose of your simulation? Everything depends on that.
2. I really don't see how you could be interested in flow details within the filter walls - not to model flow among individual fibres of the filter, I believe.
3. Tim's suggestion about pressure jump internal boundary seems really the only sensible thing you need to do.
Regards George
Old   June 2, 2004, 01:44
Thiyagarajan
thanks Tim and George,my problem is to study the filter efficiency and pressuredrop when dusty air passes through the filter, iam using DPM to trap the sand particles on filter surface.so i can't use porous jump condition.what could be the maximum value of aspect ratio used with Fluent with Hexa mesh. regards Thiyaga.
Accumulating Dust on a Filter Cartridge WalterW CFX 21 May 26, 2020 07:23
Simulating a Paper Filter in Multiphase: How to Make Impassable by Secondary Phase? VT_Bromley FLUENT 0 February 24, 2011 00:27
EFD Meshing White Paper John Parry FloEFD, FloWorks & FloTHERM 0 April 10, 2008 11:20
Modelling of Filter paper and paint coating Karthick FLUENT 0 June 8, 2004 08:14
Modelling of Filter paper and paint coating Karthick FLUENT 0 June 2, 2004 07:20
