Parallel processing
Old   May 27, 2004, 07:07
Default Parallel processing
Phil
Is it possible to take a cas and data file that have been run on a single processer and then subsequently run as a parallel job using the existing dat?
Old   May 27, 2004, 08:18
Default Re: Parallel processing
Ahmed EL Kady
sure you can.
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 10:25
multiphase solver - parallel processing - GAMG thibault_pringuey OpenFOAM Programming & Development 2 August 27, 2013 23:03
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
bubbly flow and parallel processing mvee FLUENT 0 September 12, 2007 06:08
About parallel processing in Linux tuks CFX 10 August 8, 2005 09:22
