HELP! Problem on Animate
Old   May 26, 2004, 05:03
Default HELP! Problem on Animate
Benz Wolf
Problem on Animate (FLUENT 6.0.12)
I established a 3D model in order to simulate a huge heat storage tank. I want to make FLUENT record automatically the temperature contour in the tank as frame so that I can convert them to *.mpeg file. But the *.hmf files which should be written in the certain directory by FLUENT had no actual data at all!
My setting course: 1)set all the boundary conditions; 2)the velocity field has been simulated accomplished, only the energy equation be solved; 3)set up a directory named ˇ°t-contourˇ± in the local directory; 4)Solve -> Animate -> Define: set 1 Animation Sequences named ˇ°t-contourˇ±, record every 600 iteration steps. In ˇ°Defineˇ± of Solution Animation panel, set a cross section plane contours in ˇ°Display Typeˇ±, the contours were written in local directory which was set up earlier. 5)start to iterate.
Thanks!
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
