Skewness -> Reversed Flow
Old   May 26, 2004, 04:26
Default Skewness -> Reversed Flow
krishna
hello All,
I am trying to simulate the flow around a NACA aerofoil with a sufficient amount of wing span, therby making it a 3D problem, as i want very reliable values, I am imposing a Structured mesh around it, a bit highly dense, the inlet condition is "VELOCITY INLET", whereas the Outlet is Defined as "OUTFLOW" in Fluent, and for the initial cases only Laminar Flow is Considered.
after few iterations I get "Reversed flow", will this have a considerable effect on my solution, and also the residuals seem to Fluctuate a lot, as far as the skewness is concerned, the maximum skewness of the Hexahedral Cells is 0.89, Is this skewness within limits for structured grid congfiguration.
Thanks In Advance,
krishna.
Old   May 27, 2004, 09:49
Default Re: Skewness -> Reversed Flow
zachi
Hi, concerning the skewness factor you should check your grid in gambit (also equiangle skew, side ratio,...). Concerning the reversed flow I would try the pressure outlet boundary condition. regards
zachi
Reversed Flow in Outlet Steve FLUENT 18 March 30, 2013 08:50
Severe nonorthogonality and severe skewness problem qtian OpenFOAM Running, Solving & CFD 2 January 22, 2008 19:47
reversed flow Sastry FLUENT 5 March 22, 2007 09:05
reversed flow Lakshmi Kanth FLUENT 1 September 26, 2005 06:30
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
