postprocessing- unsteady flow
Old   May 25, 2004, 06:16
Default postprocessing- unsteady flow
Bastian
Hallo everybody! How can I postprocess the data of the autosave option over the time. I don't want to analyse the data at a particular time step but over the whole flow? Regards Bastian
Old   June 2, 2004, 02:54
Default Re: postprocessing- unsteady flow
Arun
Hi !
If you wanted time history of the variables, you should have set surface monitors. Create points at the location where you want your data and also set the required surface monitor before the start of the simulation. All the best.
Arun
Periodic boundary in unsteady flow ac2011 FLUENT 0 September 26, 2011 07:52
Unsteady Flow Postprocessing Arturo FLUENT 3 January 14, 2003 02:04
Unsteady Boundary Layer Flow Wen Long Main CFD Forum 0 July 30, 2002 00:08
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
CFX- Particle tracking in Unsteady flow faithkim Main CFD Forum 3 September 14, 1999 21:57
