problem about unsteady
Old   May 16, 2004, 22:39
Default problem about unsteady
lingo
Hi,everyone:
In my unsteady case,I set the step size=T/20(T refers to a period).However ,after one step,the solution has converged quickly.In the next steps ,only"solution converged"appeared .
Could you give me any advice ?
Old   May 17, 2004, 04:14
Default Re: problem about unsteady
niyati
jfkdjfdkfjdkfj
Old   May 17, 2004, 04:50
mateus
Hi!
Residuals are already below your criteria in the next time step. I think you shoul decrese the time step and set residuals to lower values (10^-4).
regards MATEUS
Old   May 19, 2004, 07:33
lingo
Hi,mateus:
Thank your for your advice.I'll try it.
best wishes for you!
Under Relaxation Factors(URF) in unsteady problem Maxmum FLUENT 0 August 14, 2010 19:00
conditions for unsteady problems dvdromnu OpenFOAM Running, Solving & CFD 5 November 9, 2009 03:15
unsteady state velocity problem Vedavyasa M FLUENT 0 June 28, 2007 07:33
Problem in Reporting Unsteady Particle Fates Nelson FLUENT 0 August 23, 2006 21:24
unsteady state problem prasad FLUENT 0 April 4, 2002 23:44
