Build mesh or fluent
Old   May 12, 2004, 19:51
Default Build mesh or fluent
Josh
Hey, I have a channel mesh built by Gambit, I want to duble the channel length.I copy my old mesh and move to the end of the first mesh. what boundary type should I specify for the middle two planes(one plane is the end surface of the first mesh and the second plane is the begin of the copy mesh)? Or just leave default the Flent6 can automatically read them and connect these two meshs as a new double length channel.
Thanks
Old   May 13, 2004, 05:05
Default Re: Build mesh or fluent
ap
You don't need to specify any boundary condition. You have to connect the two volumes using GAMBIT connection functions.
Hi
ap
Old   May 13, 2004, 17:10
Tim P.
Ap's way is the easiest but, for whatever reason, if you do want/need to keep the two volumes as seperate entities then you could define each of the two faces that meet each other as interface (boundary condition). Then mesh each volume as you normally would keeping in mind that there are two distinct faces where there only appears to be one. Then once you import into FLUENT go to Define->Grid Interfaces, name your grid interface and select the two faces that you designated in Gambit as "interface" and click "create".
Cheers, Tim.
Old   May 13, 2004, 18:32
Josh
Thank Ap and Tim
I hope Tim explain for me more clearly. I am a newhand. In my unstanding, the "interface" means between the "fluid" and "solid", but my problem is only extend the channel grid, that means two same "fluids", can I still use the interface?
Thanks Josh
Old   May 18, 2004, 08:53
ap
Connecting faces keep volumes separated, you just have to define different fluid zones in GAMBIT if yon need it.
Hi
ap
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 15 March 3, 2016 18:29
Can anybody tell me what does fluent do using MESH MOTION? enry FLUENT 0 October 6, 2010 13:54
Fluent: Mesh Adaption based on Gradient enigma FLUENT 4 July 15, 2010 18:36
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
Import ICEM Mesh to Fluent Fluent Beginner FLUENT 5 June 23, 2004 01:27
