Importing *.cas from fluent to gambit
Old   May 11, 2004, 17:38
Default Importing *.cas from fluent to gambit
Peter
May I ask you a question about importing?
I'd like to import *.cas file from Fluent v6.1 to Gambit v2.0. I tried sevral times to import it, but couldn't make it. Is it possible to do that? The reason I want to do it is that I need to look at how meses are generated and I want to apply another case with it.
Thanks in advance.
Old   May 11, 2004, 19:20
Default Re: Importing *.cas from fluent to gambit
Ajay
Yesh this could be done. I have tried this This is what i do File > Import >mesh > Specify Fluent 5/6 in the type drop box and specify 2D / 3D > browse for your cas file and Accept does it for me. -Ajay
Old   May 11, 2004, 20:31
Peter
Thanks for your answer. I followed your direction, but I am still in trouble with importing it. In Gambit is an error showing "Gamit is unable to import.....". What's wrong with me? I also tried to import an example file given in Fluent.Inc. The problem is same. Dear Ajay, could you try it with my case file? If you don't mind, I can email you.
Thanks agian, Peter
Old   May 12, 2004, 10:33
Ajay
Yes please send it across I shall try on my machine remove the -nospam in my email id to mail me. arao-nospam@uh.edu
Old   May 14, 2004, 07:06
venu gopal
Haai, This is venugopal from IITMADRAS. I think you problem is due to version problem. fluent 6.1 is not compatable with the gambit 2.0, you have to go for some higher version of gambit 2.1. I faced this problem and upgraded my gambit version. You just try with the higher version of gambit Bye Venu gopal
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 pdilly FLUENT 23 April 2, 2016 13:10
[GAMBIT] BC's value assignment in Gambit Vs. Fluent (solver) hadikhayyamian ANSYS Meshing & Geometry 5 December 21, 2010 13:28
Global c.sys in GAMBIT or FLUENT Kasper Skriver FLUENT 4 November 10, 2010 13:49
Fluent case file into Gambit Eric R. FLUENT 7 July 17, 2002 15:11
Grid for Fluent v.4 using Gambit? Ray Main CFD Forum 3 October 27, 1999 13:35
