moving heat source on fluent
Old   May 10, 2004, 10:36
Default moving heat source on fluent
isaac
Can fluent modeling a moving heat source on a surface using UDF fonction and how?.The heat source is a moving laser spot heating a solide surface. and I would like to watch the transient nature of the surrounding temperature profiles. Please help me. thanks to all
Old   May 11, 2004, 19:05
Default Re: moving heat source on fluent
STK
YOU CAN HAVE A MOVING SOURCE. FIRST OF ALL, TO CREATE A SOURCE YOU MUST ADAPT A REGION AND THEN CREATE A SEPARATE CELL ZONE.(UNTIL HERE I HOPE YOU AGREE). THIS CELL ZONE IN 2-D HAS 2 INTERIORS ONE IS THE OUTLINE AND THE OTHER THE CELLS INSIDE. YOU IMPOSE YOUR CONDITIONS TO BOTH (DYNAMIC MESH ZONES IN DYNAMIC MESH PARAMETERS).YOU HAVE TO MAKE A C++ FILE DESCRIBING THE MOTION OF THESE ZONES WITH THE CLASSIC COMPILING PROCEDURE.
Old   May 12, 2004, 07:28
Default thanks STK
isaac
thank you very much STK.CAN I GET YOUR MAIL? I HAVE DONE A SIMPLE MODEL TO SHOW YOU THE PROBLEM I AM MODELING.I AM A NEW USER OF FLUENT 6.1.22 AND I HAVE READ THE TUTORIAL OF GAMBIT AND FLUENT BUT I HAVE NOT A SOLUTION .
Old   February 2, 2017, 05:21
ARJUN A ASOK
ARJUN A ASOK is on a distinguished road
I am doing my project work in ansys fluent weld pool simulation.Could you please provide me with a udf for simulating a moving heat source in fluent.
ARJUN A ASOK is offline   Reply With Quote
How to model a moving heat source? James FLOW-3D 14 June 29, 2020 09:46
Heat source function of mass flow MarcVi Fluent UDF and Scheme Programming 0 September 16, 2010 14:16
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
heat source in a domain aydin FLUENT 0 January 3, 2003 08:01
