Grid size and VOF accuracy
Old   May 9, 2004, 23:44
Default Grid size and VOF accuracy
Ryan
I use VOF model to compute a free surface flow, the fluctuation range in vertical direction of the surface is just several tens of microns, even smaller. I want to make the accuracy as high as 1 micron.
Question: 1. What grid size should I decide around the surface? Now it is 5*5 microns, is it enough? 2. What accuracy can the VOF model in Fluent reach? Where can I find some materials of its accuracy analysis?
Thanks & regards.
Old   May 10, 2004, 07:33
Default Re: Grid size and VOF accuracy
Boris
The problem you are solving is quite interesting. How can Fluent be used for such a microscopic flow? Is the continuum theory valid for such a flow?
Regards.
Old   May 10, 2004, 08:59
Ryan
Actually, the domain is a macroscopic flow, but the fluctuation is very small. the grid size of 5*5 microns is just the minimal cell in the whole domain.
How to find droplet size in VOF?? tejas.kullarwar FLUENT 0 March 21, 2011 03:26
VOF interface compression and mesh size idrama OpenFOAM 1 September 26, 2010 07:36
VOF and the size of air region??? yasser CFX 2 October 11, 2006 05:59
grid size MER Main CFD Forum 6 August 22, 2004 05:38
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 09:25
