May 7, 2004, 12:05 |
correct turbulence model
I have a few questions about the correct selection of a turbulence model.
the flow is in the headspace of a tank exposed to ambient conditions. the headspace as a pressure outlet at the top. working fluid is air and since characteristic length is about 2 m, even for temperature difference of 5 K, rayleigh number goes in the transition region around 10e8 to 10e9 Is K omega model the only option for me? Can I use K epsilon for this case? Will K epsilon with RNG be a better choice? If I want to use std wall functions for K epsilon, I have to keep the cell thickness at the wall pretty high, that makes the whole grid too coarse -- so I am clueless there. If I go for K epsilon with enhanced wall, i know i need to maintain y+ around 1, but i have seen it go as high as 3. In one case, it went up to 10 -- IS that bad? will that give wrong results? Do I need to step back and rerun that time part with refined mesh? \ Please shed light on whatever questions you can. thank you, CO2 |
May 7, 2004, 15:23 |
Re: correct turbulence model
Hi, About the enhanced wall treatment, you may need to follow the instruction given by Fluent, i.e. maintain y+ around 1. you may need to refine.
OpenFOAM: LES turbulence model names | Ollie | OpenFOAM | 5 | January 7, 2013 11:24 |
Is this understanding of turbulence models correct? | 3kha | Main CFD Forum | 3 | January 31, 2011 22:31 |
build your own turbulence model with buoyancy | Thomas Baumann | OpenFOAM | 11 | November 23, 2009 09:53 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 06:15 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
