heat generation rate w/m3 in 2D
Old   May 6, 2004, 10:35
Default heat generation rate w/m3 in 2D
Laszlo
Please help me understand the specification of heat generation rate. In electrical circuit boards the heating power is exactly known for example 1mW. Heat generation rate can be specified as a property of solid zone. I know the size of electrical heat-emitter-body so I can calculate w/m3. But how could I know if it is correct or not because the solver is 2 dimensional? I think Fluent use this heat generation rate to calculate heat without knowing the 3rd dimension of the heater body. Is it a bug in Fluent (should use w/m2 instead of w/m3 during 2D simulation) or I don't understand something?
Thank you for your answer!
Old   May 6, 2004, 12:58
Default Re: heat generation rate w/m3 in 2D
co2
Dear Laszlo:
I will tell you what I know.
I also use w/m3 values for my 2d Axisymmetric flow calc. As far as I know, for 2D axi calc, fluent calculates the total volume by rotating your area around the axis by 360 degrees.
In 2D calc, I think thickness of 1 m is assumed -- so do your calcs accordingly. Some one please correct me if i am wrong -- Quite possible.
Thanks, CO2
Troubles with heat release rate Xavier Ponticq CFX 4 September 12, 2012 19:49
UDF for heat generation prince_pahariaa FLUENT 4 July 11, 2011 03:58
Diesel combustion simulation ( Heat release rate) venkatesh Siemens 2 April 29, 2009 08:38
Inconsistent Total Heat Transfer Rate Ken Adams FLUENT 0 July 24, 2007 12:04
Heating of a solid cylinder with internal heat generation Sriram Popuri Main CFD Forum 6 July 13, 1999 19:09
