Help! I cann't make library
Old   May 6, 2004, 08:08
Default Help! I cann't make library
Bowling
I don't understand how to complied UDF.
This messege was happened.
Opening library "Test.c"... trying library "Test.c.dll" trying library "Test.c\ntx86\2d\libudf.dll" trying library "Test.c\ntx86\libudf.dll" Error: open_udf_library: The system cannot find the path specified.
Error Object: ()
So, I don't know how to build library. I confuse in the help too. Someone can explain easy step for me please. Thank you.
Old   May 6, 2004, 13:01
Default Re: Help! I cann't make library
co2
Dear Bowling:
Please read the following page carefully. If you are using Fluent 6.1, compiling UDF is very easy. Just follow the instructions correctly..
www.fluentusers.com/support/installation/winfaq/nmake.htm
Old   May 7, 2004, 06:12
Shanice
are you using Fluent v6?
Old   May 10, 2004, 03:30
Bowling
My FLUENT version is 5.5. Where can I get FLUENT5.5 UDF manual? Thank you.
Old   May 11, 2004, 09:08
zachi
contact your fluent account manager to receive a copy or cd with the UDF-manual!
Old   May 12, 2004, 05:56
FJ
Check the followings.
-Did you set the path "FLUENT_INC" correctly in your computer?.
-Did you change the content of "user_nt.udf" and change the name of "makefile_nt.udf" to "makefile"?
-Is "nmake" command carryed out under the ntx86\2d or ntx86\3d?.
Compiling UDF of Fluent5.5 is bothering us compared with Fluent6.x.
Thank you
FJ
Linking problems dynamic library Van de Leur OpenFOAM Programming & Development 17 August 2, 2012 11:52
[OpenFOAM] paraFoam not found maysmech ParaView 26 October 25, 2011 04:14
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Star-ccm+ format import in Saturne code and install libccmio library . rezki STAR-CCM+ 0 July 29, 2010 05:01
[Q]How to make MPEGs with CFD datas??? Bum-Seok Hyun Main CFD Forum 4 February 16, 2000 19:59
