creating a face
Old   May 5, 2004, 01:02
Default creating a face
patrick
Hi, I tried to create a face by joining the existing wireframe, but I got error saying "The vertices and edges must be coplanar", how do I get around this?
Also, I tried to stitch faces to form a volume, but there's a warning that says " An edge on the volume resulting from the face stitch changes convexity. Set the GEOMETRY_VOLUME_SPLIT_AT_CVXTY_PTS_IN_FACE_STITCH default before the face stitch operation may be recommended". I'm lost. Can anyone help me?
Thanks alot
Patrick
Old   May 6, 2004, 10:24
Default Re: creating a face
Laszlo
If you create surFACE it must be plain. As the top of quiet water. "The vertices and edges must be coplanar" means something is higher or lower than other parts.
You create points after it you create edge-lines between points after you can create face from wireframe-lines. You must select the lines in clockwise or back-clockwise order during the selection the wireframe lines else you get trouble with simulation.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
