turbulent viscosity limited to viscosity ratio
Old   April 30, 2004, 03:26
Default turbulent viscosity limited to viscosity ratio
mukkarum
Hi
My solution is going to converge but after each iteration I am getting messege that " turbulent viscosity limited to viscosity ratio 1.000000e+05 on x cells". I am using realizable k-epselon model with standard wall function.
Anyone please help me to get rid this problem.
Thanks
Mukkarum
Old   April 30, 2004, 05:26
Default Re: turbulent viscosity limited to viscosity ratio
ap
This problem usually happens if you have a too coarse grid somewhere in your domain. Plot a contour of the viscosity ration and try to refine the grid there.
Look for other messages on this subject too, there are a lot of questions and answers in this forum.
Hi
ap
Old   May 7, 2004, 03:33
Pravin Naphade
In fluent u just goto
SOLVE.....CONTROLS.....LIMITS .. in limits increase the value of Max. turbulent viscosity ratio to 1.0e10+07... ..it is just the limit...it will not affect ur final solution.....afterward u will not get the mentioned message and u will get faster convergence..CERTAINLY ..try once best luck!
Old   May 11, 2004, 05:05
ap
I don't agree. The limit on turbulent viscosity ratio has been introduced to obtain a stable numerical solution, but it's not necessarily correct.
FLUENT sets the limit using a value which is acceptable in many cases, but if the limitation takes place it could affect the solution.
Hi
ap
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 511831 cells ZQWY FLUENT 18 June 8, 2023 12:36
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 12:04
Turbulent viscosity limited to viscosity ratio of 1.0000000e+5 eespi002 FLUENT 3 June 30, 2009 14:24
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 21:34
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
