April 24, 2004, 19:45 |
energy source term W/m3
hi all,
I am running a 2D axisymmetric unsteady problem. I have a solid zone for which I want to specify engery source terms (W/m3). I have these values in a profile file and I am reading those values from there. But when I try to run my model, I get access violation erro. It gives some chip-exec error and tells me that the particular term in the profile file can not be accessed. following are the details Error: chip-exec: function "qvolTANK2" not found. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () Has anyone come across this error? what is the solution? |
April 25, 2004, 10:46 |
Re: energy source term W/m3
hi,
i solved this problem by writing a simple define source udf. is it true that profiles files can not be used for writing source terms in Fluent? |
April 25, 2004, 21:35 |
No, you can't specify it. Profile file is for a certain face value at specified BC. FJ |
Problem of SOURCE term gradient in UDS | wind | Fluent UDF and Scheme Programming | 6 | December 1, 2022 14:21 |
add source term to energy equation by udf | tomas | Fluent UDF and Scheme Programming | 7 | September 10, 2013 02:08 |
Mass and energy source - evaporation | neilduffy1024 | ANSYS | 4 | July 16, 2013 23:50 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 13, 2000 23:03 |
