Species Transport model
Old   April 22, 2004, 10:54
Default Species Transport model
Karthick
Hello All
Now I am dealing with Species Transport Model. I am having some doubts. I am having around 8 fluidisation reactions. But corresponding rate exponents, Activation energy, Preexponential factor, mixing law and other parameters, I don't know. All are mostly experiment related aspects. Is there are any sources where I can get all these values?
Also what is the possibility in Species transport model to specify whether the reaction is exothermic or endothermic?
Regards Karthick
Old   April 22, 2004, 11:22
Default Re: Species Transport model
co2
wiht exho or endo i guess you can just do that by changing the sign of energy source term in your zone
Old   April 22, 2004, 12:01
Karthick
Dear co2
How I can specify exothermic and endothermic for each reaction. Totally I am having 8 reactions that has to take place in all the zones. It is just gasification reactions.
Also where I can get the activation energy, preexponential factor, rate exponent values?
Regards Karthick
Old   April 22, 2004, 12:21
co2
NIST has a very good web resource.
http://www.nist.gov/srd/onlinelist.htm
you got to be able to pick up something
Old   April 22, 2004, 12:49
Allan Walsh
Not sure what type of project you are working on, but it sounds like you are just starting out. If you are doing this as a student project, then you can find many sources of kinetic rate data on the Internet with a quick search, which should suffice.
If this is a "real world" project, you probably should know that people spend years or decades trying to get the information needed. More rigorous reaction schemes may involve hundreds of species. Sure, this can be reduced to a simple rate expression, but is it valid for your conditions? Good enough? Takes lots of time to check these things.
Exothermic versus endo depends on what is entered for the heats of formation of reactants and products. Fluent 6.x has lots of stuff built into the database.
A good place to start is by first looking at the documentation, and then asking questions.
questions about species transport through walls shuqin FLUENT 13 April 9, 2014 03:42
Divergence problem for species transport model MY FLUENT 3 January 11, 2014 05:46
species transport model or mixture model? achaokaoyan Main CFD Forum 0 July 10, 2010 11:52
species transport in water lyn FLUENT 1 December 12, 2007 19:15
Can Fluent handle species transport in multi-phase Roger FLUENT 1 January 30, 2003 20:12
