April 21, 2004, 16:52 |
initialization
question: In a particular 3D unsteady problem let us say I obtain solution for some first 20 time steps by using very low under relax parameters. Now that the flow is developed, I want to start again at t=0 and use good values (default) for under relax parameters. How do I use the solution obtained previously to initialize my new problem?
April 22, 2004, 06:23 |
Re: initialization
You can export the solution using the File->Write->Profile command from the first grid, initialize your solution and reading profiles again.
Maybe there is a better way, but I don't know it. Hi ap |
April 22, 2004, 11:15 |
Re: initialization
does profile files contain all the data at nodes ? i was thinking the dat file does that
FMG initialization query | Mohsin | FLUENT | 6 | November 2, 2016 03:02 |
code initialization - exclude pressure | edna | Siemens | 0 | January 29, 2008 11:56 |
Initialization | a student | Siemens | 2 | May 19, 2006 13:55 |
compressor initialization | paglia | FLUENT | 0 | February 1, 2006 16:14 |
INITIALIZATION & SORSCA | july | Siemens | 1 | May 31, 2002 03:55 |
