batch file script to run unsteady flow (les)
Old   April 20, 2004, 04:50
Default batch file script to run unsteady flow (les)
andi
I need a batch file to run an unsteady simulation using LES in fluent. I would like to start with a steady state case and data file using some simple turbulence model, say k-e.
Then I would like to start the unsteady analysis for a certain time period using a specified time step.
Then I would zero out the initial statistics and start the actual unsteady analysis using some time step for a certain number of time steps and also enabling data sampling, so that I can see the mean values.
Thanks for your help.
Andi
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
