3D nozzle
Old   April 16, 2004, 20:00
Default 3D nozzle
jacky
I try to model the air flow through a nozzle, can anyone tell me what is the best way to setup the flow domain and what boundary conditions to use, if i only know the up and down stream pressure and the the throat is choked.
Old   April 20, 2004, 05:22
Default Re: 3D nozzle
Nandu
if the throat is choked then the downstream conditions dont matter (as they will be supersonic, in the case of a diverging section after the throat) unless you have a normal shock in the nozzle past the throat.
Set up the simulation using the coupled explicit solver, and do an inviscid calculation to start with. Pressure based inlets, or far field boundary as inlet. Pressure as outlet (will be ignored if the outflow is supersonic).
cheers nandu
Old   April 20, 2004, 12:34
jacky
thank you for your reply, it is very helpful!! i wonder if u can help me with another problem? i want to find the highest exit pressure of the diverging section, while the throat is still choked, and the flow down stream is subsonic.
many thanks!!
Old   May 6, 2004, 04:09
Nandu
this would mean that there is a shock wave in the the diverginging section of the nozzle just downstream of the nozzle throat. the explanation of how this can be calculated can be found in any decent gas dynamics text book. it is an iterative process to match the pressures across a normal shock with supersonic upstrem conditions.
cheers nandu
Convergent Divergent Nozzle Hrishikesh Main CFD Forum 12 June 25, 2016 03:06
Nozzle Flow - Divergence Problem Ijaz FLUENT 9 January 11, 2014 05:36
C-D nozzle supersonic jet boundary Gland FLUENT 4 May 24, 2012 01:25
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 12:46
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
