Cell Temperature using udf
Old   April 15, 2004, 05:18
Default Cell Temperature using udf
Karthick
I need to take the temperature of each cell from my model using udf. But C_T(c,t) is not working well in case of Multiphase Eulerian model. In case of Eulerian model, how I can get the cell temperature.
Regards Karthick
Old   April 15, 2004, 06:56
Default Re: Cell Temperature using udf
thomas
I do comfirm you that C_T works perfectly with eulerian model. Check if you are using the right threads, or if you have simply activate the energy equation ! Thomas
Old   April 19, 2004, 07:29
Mahesh
Yes, I have also used and checked with Eulerian Model. It works fine. Use proper thread to access it. U have to get the pointer to reqd. phase and use the macro.
Mahesh
Fixed Temperature Cell in Solution ozzythewise OpenFOAM Pre-Processing 22 February 24, 2012 06:56
interchanging face information with cell information/ radiation flux UDF ximik FLUENT 1 May 4, 2011 17:34
how to write a 3D linear temperature of UDF venus FLUENT 1 October 28, 2008 03:46
udf for varying inlet temperature aravind FLUENT 0 October 27, 2008 11:08
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
