April 14, 2004, 18:33 |
Air foil, drag coefficient
I am trying to model an airfoil using k-epsilion model (standard wall treatment). Inlet air velocity is 100 m/s with 12 degree angle of attack. I get unusually large values for drag and lift coefficients (approx. 6000). What am I doing wrong?
April 15, 2004, 01:21 |
Re: Air foil, drag coefficient
Hi, as you know Cx = X/D, where D = 1/2*rho*U^2*A, rho - density, U - velocity, A - area, X - force. FLUENT uses values which are specified in FLUENT reference panel (in FLUENT menu: report->reference values) by default. I think you must set correct values for density, velocity and area there.
regards |
April 16, 2004, 01:40 |
Thanks Dmitry.... that did the trick !!
Drag Coefficient Convergence Problem | John | FLUENT | 18 | June 24, 2023 10:22 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 07:24 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
