UDF compilation error
Old   April 13, 2004, 10:21
Default UDF compilation error
Szabolcs Varga
Dear All, Some days ago I had a problem of interpreting an UDF. I got help immediatelly, giving me the hint to compile the source code instead of interpreting it. So I did, but now, I got a new error message regarding to nmake:
Make sure that UDF source files are in the directory
that contains your case and data files. If you have an
existing libudf directory, please remove this directory
to ensure that the latest files are used. 1 file(s) copied.
1 file(s) copied.
1 file(s) copied.
1 file(s) copied. (system "move user_nt.udf libudf\ntx86\2ddp")0 (system "copy H:\FLUENT6.1.18\fluent6.1\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2ddp")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
Could you please comment on this? Thank you, Szabolcs
Old   April 13, 2004, 11:27
Default Re: UDF compilation error
ap
First of all, put your UDF source code in the same directory where you saved the cas and dat file of your simulation.
Also, the message
nmake is not recognized as an internal or external command
means that FLUENT can't find Microsoft Visual Studio command line compiler. You have to install it and to set PATH in order to use compiled UDF on a Windows platform.
Hi
ap
Old   April 14, 2004, 11:12
Karthick
Hai
I also faced the same error some time back. But after that instead of compiling, I try to interpret it. Now it is ok. Let u first try interpret and after that compile it.
I think we can do any of the things, interpret or compile.
Regards Karthick
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
