Lift prediction in turbulent models
Old   April 13, 2004, 06:57
Default Lift prediction in turbulent models
BART
I am having serious thoughts about the lift calculation using a turbulence model. I am working with a NACA0015 profile that has a lift coefficient of about 0.06 at an angle of attack of 3 degrees. The model I use is Spalart Allmaras. Can anybody tell me something about the reliability of the calculated lift and drag forces using this model?
Old   April 13, 2004, 10:22
Default Re: Lift prediction in turbulent models
CFD Rookie
As far as I know, SA model is good when there is adverse pressure gradient in the calculation.
I have been working on 2d airfoil (eg NASA LS(1)-0417, some Clark Y etc) analysis for the past two months, and based on my experience, lift is really good (a few % off) but Drag goes to "hell". There are lots of issues why your drag doesn't match up well enough, could be y+ problem, domain size, etc. Have you conducted analysis at high alpha also or currently just the 3 degree alpha case.
Can you be more specific about what you have done (during the problem setup) and what types of results you obtained that you think is not good enough!
Old   April 13, 2004, 10:49
BART
Thanks for all the trouble, but the problem has already been solved. The lift coefficient (3d calculation, Y+ was good) was lower because the aspect ratio of the wing is relatively small (1.3). Also the reference area is redefined leaving a satisfyable value for Cl. Thanks for the help!
Old   April 14, 2004, 02:15
varad
Quick question,
With the three-d model, how are you rotating the 3d profile of the blade. Im using a NACA012, but, they are ducted and due to close clearances meshing is very tough.
Are you guys using sliding meshes?
Laminar doesn't converge; Turbulent models do? Amit FLUENT 11 April 23, 2015 23:55
Two-equation turbulent models: low re airfoils truffaldino Main CFD Forum 51 March 19, 2012 19:57
Lift & Turbulent Dispersion in Stirred Tank ozgur FLUENT 0 April 23, 2007 11:01
Laminar vs. Turbulent Models Dahvid Brown FLUENT 3 October 23, 2000 03:36
