what should I do if the solution didn't converge?
Old   April 7, 2004, 10:04
Default what should I do if the solution didn't converge?
Beeny
hi all!
If the solution (mass) didn't converge, what in general should I do to check it and amend it?
Benny
Old   April 7, 2004, 11:04
Default Re: what should I do if the solution didn't conver
John
try changing the termination restriction in Solve..>Controls..>Multigrid from it's default value 0.1 I Think to 0.001.
bye
Old   April 7, 2004, 18:57
ap
First of all, try to reduce under-relaxation factors a bit. If this is not enough, try to obtain a solution using the first order discretization scheme, then switch to higher order.
Also a good quality grid and proper boundary conditions are required to get good convercence rate.
Hi
ap
Old   July 27, 2011, 10:36
Nitin
rob sharma is on a distinguished road
Guys i have a big problem like my solution is not converging in simple case. I have a pipe 800 mm lenth and 15 mm dia. I am using axis-symmetric pipe. I simulate that pipe with inlet velocity 0.486 by using 800 nodes in length and 8 in readiusof pipe for laminar flow. It is simulated at around 246 iterations. But after after increasing nodes in length that is of 1200 and 10 in radius of pipe, it does not converger. If i give initail velocity less like 0.470, then it converges. But the result does not come appropriate. all my values come under the convergence criterion of 0.001. but the continuity does not come. i dont know what to do. If anybody tell me i will bw very thankful...kindly...
rob sharma is offline   Reply With Quote
Old   August 13, 2011, 00:31
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hi Rob,
I think the convergence of simulation based on:
1. Complexity of geometry
2. Mesh size, quality.
3. the precision of the simulation (single or double)
4. Turbulence model choice
5. Discritization method (first order,second order and so on)
6. Our physical input
7. setting under relaxation factor (the setting of under relaxation factor is depend on gauss seidel method)
I think you can analyze your case based on those things.
Hope it helps
teguh
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   August 13, 2011, 07:09
Default convergence problem
Nitin
Its a laminar flow with 1200 nodes in length and 10 in radius. Anyone could suggest me the book or reason why does the solution not converge. I need to know the reason.....kindly please help me.......
Old   August 27, 2011, 01:04
teguhtf's Avatar
teguh hady
He there,
For internal flow, i think you should choose turbulent mode. because, i think there will be little turbulence generated near the wall. If you're sure that there is no turbulence, you can choose laminar mode.
Teguh
Now Or Never!!!
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 08:51
simple algorithm, converge of solution bbasal Main CFD Forum 0 February 13, 2010 03:58
Solution Does Not Converge Rif Main CFD Forum 3 March 7, 2008 06:33
My Solution wont Converge!!! Chris FLUENT 6 April 16, 2005 19:57
what to do when solution doesn't converge? Jenny CFX 5 January 28, 2004 05:00
