How to define PDE BC with UDF?
Old   April 6, 2004, 01:10
Default How to define PDE BC with UDF?
KKLAU
To all Fluent experts all over the world,
I am facing problem for defining BC involved PDE with UDF. Can somebody give me a hand? My PDE BC is
div(v)/div(y) = v + constant
where v = velocity in y direction
Thanks alot...
KKLAU
Old   April 6, 2004, 03:28
Default Re: How to define PDE BC with UDF?
FJ
We can define it via UDF.
div(v)/div(y) is defined as C_DVDY(c, t) in UDF macro and this macro is for cell values .
So when we use this macro at a specified face via DEFINE_PROFILE , we have to define C0 and THREAD_T0 in the macro.
Thank you
FJ
Old   April 6, 2004, 09:35
thomas
Hello, Before asking all those question you should read the fluent documentation in order to knwo what are the BC you can use, and then how to modify them using a UDF. To answer your first message about how to fix the BC div(v)/div(y) = v + constant. What I am proposing to you is to use a Velocity inlet. From there you can descretize your equation div(v)/div(y) = v + constant and easily calculate via UDF your velocity v. Then using a Velcoity Inlet you are gonna attached this velocity to your BC.
Thomas
Help! DMFC UDF problems Biao FLUENT 1 November 2, 2020 08:39
define wall functions (UDF) in Fluent 6.3 Alex FLUENT 6 August 3, 2017 08:45
How to use UDF to define a moving wall lingo FLUENT 9 August 19, 2014 10:14
Help: using udf to define direction Bo FLUENT 1 July 16, 2008 07:47
Define wall using UDF Abhijit FLUENT 3 October 26, 2007 11:16
