How to use UDF to define a moving wall
Old   April 5, 2004, 06:17
Default How to use UDF to define a moving wall
lingo
Hi,evryone: My problem is that:in a centrifugal pump,the impeller(wall) is rotating with sin(t),so the fluid zone is also rotating .I just know a UDF is needed to define this.But I don't know whether I define the moving wall or define the fluid zone or both?Which Macro will be needed?How to define? can you give me some advice? Thank you!
Old   April 6, 2004, 06:42
Default Re: How to use UDF to define a moving wall
emma
I think you can use the macro "DEFINE_CG_MOTION" to define the motion of the moving wall if you are using dynamic mesh modeling. The fluid zone is normally described as "deforming". As I remember, you can also work with MRF(multipul referance frame),mixing plane or sliding mesh model.
Please see fluent user's guide, chapter 9 and UDF manual.
Hope it helps.
Emma
Old   April 7, 2004, 00:49
Ady
You will need to use the Dynamic meshing model. You can not use reference frame models for this. Fluent does not have the hook for the UDf under fluid bounday conditions panel for omega as a function of time.. Use Dynamic mesh model and define wall to be rotating wall.
Use DEFINE_CG_MOTION macro for prescribing motion. Use smoothing-remeshing algo for the fluid domain to activate the remeshing tin the domain.
Best, Ady
Old   April 8, 2004, 05:43
lingo
Emma,Ady:
Thank you for your advice .I never thought of using the Dynamic meshing model .I'll try it. Best wishes.
Old   April 8, 2004, 09:05
Guess
You can define the fluid rotation using UDFs even though you don't have hook to attach the UDF
Use DEFINE_ADJUST macro and THREAD_VAR(tc).fluid.omega = your function
to define the rotation
enjoy!
Old   April 9, 2004, 23:24
lingo
emma,Ady:
I met a problem.When I activate the Dynamic Meshing and OK,someting as follows appears in my console window:
"Could not check out fluent-mdm-beta: No such feature exists Feature: fluent-mdm-beta License path: D:\FLUENT.INC\license\license.dat; FLEXlm error: -5,357 For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com".
Error: unable to acquire a license for the moving/deforming mesh model.''
what's wrong ? How to solve it?
another question: I only can activate the "parameter"in "Dynamic meshing" ,how to activate "the zones" in "Dynamic meshing"?
Thank you for your help!
Old   April 9, 2004, 23:37
lingo
Hi,Guess:
I still don't catch ¡°THREAD_VAR(tc).fluid.omega = your function¡±.I know little about the variables in Macro¡°DEFILE-ADJUST¡±. I try to write a udf :
#inclue ¡°udf.h¡±
DEFILEA¡ªADJUST(my£*adjust,d) { Thread*t; cell-t c
thread -loop-c(t,d) { begin-c-loop(c,t) THREAD-VAR(tc).fluid .omega=5*sin(5*t); end-c-loop(c,t) } }
Can you check it for me? Thank you very much.
Old   April 19, 2004, 04:19
Guess
#include udf.h
DEFINE_ADJUST(my_adjust,d) {
Thread *tc;
cell_t c;
real time = 0.5;
thread_loop_c(tc,d)
if (FLUID_THREAD_P(t))
begin_c_loop(c,tc)
THREAD_VAR(tc).fluid.omega = 5*sin(5*time);
end_c_loop(c,tc)
The "t" which you have used in the fn. sin(5*t), I think it should be "time". Get the time from fluent solver- I have just hard coded in the udf.
Old   April 19, 2004, 04:21
Guess
Use fluent v6.1.22! I think you are using V6.0.20 or 6.0.12...if you use v6.1, you don't require extra license to access the dynamic mesh functionalities...
Old   August 19, 2014, 10:14
Farid is on a distinguished road
Use CURRENT_TIME instead of time to get the real time of the simulation.
Farid is offline   Reply With Quote
How to use UDF to define a moving wall Big Stone FLUENT 14 February 13, 2021 08:24
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
