why results different for Compile and Interpret?
Old   April 5, 2004, 01:38
Default why results different for Compile and Interpret?
Joey
Now, I'm trying to learn how to compose UDF file. I encounter this strange problem. Please help me to solve it. I use the UDF file from the HELP file, and I just add two lines to print out the Re and Cd in the console window. If I interpret this UDF, everything is OK, a lot of Re and Cd numbers are shown in the console window. But when I compile this UDF, UDF can be used and particle can be tracked, but numbers for Re and Cd don't print now. Why this happen? and how to solve this problem? Please help me, thanks a lot!! The UDF is shown below:
UDF for computing particle drag coefficient (18 Cd Re/24)
curve as suggested by R. Clift, J. R. Grace and M.E. Weber
"Bubbles, Drops, and Particles" (1978) ************************************************** **********************/
#include "udf.h"
DEFINE_DPM_DRAG(particle_drag_force, Re, p) { real w, drag_force;
printf ("Re is %6.3f\n", Re); if (Re < 0.01)
drag_force=18.0;
printf("Cd is %6.3f\n", drag_force);
return (drag_force);
} else if (Re < 20.0)
w = log10(Re);
drag_force = 18.0 + 2.367*pow(Re,0.82-0.05*w) ;
} else
/* Note: suggested valid range 20 < Re < 260 */
drag_force = 18.0 + 3.483*pow(Re,0.6305) ;
Old   April 5, 2004, 15:12
Default Re: why results different for Compile and Interpre
ap
Try to use Message instad of printf. See the UDF manual under Additional macros.
Also, when you print a "real" data, use "%g" instead of "%f".
Hi
ap
Old   April 5, 2004, 22:26
Joey
Thanks very much. Now I get it.
Old   April 6, 2004, 18:19
ap
You're welcome
ap
interpret or compile wlt_1985 FLUENT 0 April 19, 2011 18:08
A basic doubt on reading the iteration results hariya03 OpenFOAM Post-Processing 0 July 16, 2008 09:28
interpret works fine but compile doesn't Jan Balemans FLUENT 0 March 14, 2008 10:41
Not able to interpret UDF Prasad FLUENT 1 August 15, 2007 09:44
Interpretation of Results Danial Main CFD Forum 3 October 19, 2001 14:38
