errors in calculating
Old   April 4, 2004, 00:13
Default errors in calculating
ustcer
I met some errors in simulating a turbulent flow in a 3d channel model: 1, turbulent viscosity limited to viscosity ratio of 1.000000e+5 in 12092 cells; 2, Error: floating point exception; Error Object: #f. Can someone tell me the reasons and what I should do the next? Thanks so much!
Old   April 4, 2004, 14:08
Default Re: errors in calculating
ap
The turbulent viscosity limitation usually happens if you set wrong boundary conditions for turbulence, or if you're using a mesh which is not fine enough in some point of your domain.
Try to plot contours of turbulent viscosity ratio to see where the limitation takes place.
Hi
ap
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
