Solar Heat Flux
Old   March 31, 2004, 16:49
Default Solar Heat Flux
JoHn@
Hello all; How can i model the solar heat flux falling on a wall?I've tried to use heat flux boundary condition with a value say 100w/m2, however, results are totally unphysical, i got temperatures in the range of 600 to 700k. Is it the heat flux that i should modify?suggestions please. Thanks.
Old   March 31, 2004, 22:58
Default Re: Solar Heat Flux
co2
you will need to refer to a basic solar engineering book. modeling solar heat flux is not trivial. 100 W/m2 is not a bad guess for about 2 PM time period. But again this varies from place to place, time of year, cloud cover so on and so forth .. let me know what exactly you are looking to do with solar heat flux
Old   April 1, 2004, 09:02
JoHn
Okey. I have no problem with getting the values of the solar heat flux.The problem is the boundary condition i should use with my problem.I have a 25cm thick concrete wall.The use of a heat flux is giving me crazy temperature values, in the range of 600K inside the wall! This is surely unphysical...its like i am having an isolated system where i keep adding heat to it and the temperature rises infinitely...What BC should i use? Thanks.
Old   April 1, 2004, 11:53
co2
you will need to write a UDF to release equivalent amount of heat in your wall.
heatflux (W/m2) * area of cell exposed / cell volume.
that will give u good results
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 17:25
Variable name for heat flux peterle CFX 4 February 13, 2014 03:21
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
solar heat flux through roof Tim FLUENT 1 January 17, 2007 17:01
