avoiding negative absolute pressure!!!
Old   March 30, 2004, 07:21
Default avoiding negative absolute pressure!!!
Tania
I am having problems with negative absolute pressures. does anyone know which parameters should be adjusted to avoid that. Actually, I've already read similar problem in this forum and I tried all the suggestions but it didn't help.
Thanks in advance
Tania.
Old   March 30, 2004, 09:57
Default Re: avoiding negative absolute pressure!!!
David
hello,
i read your problem all through weeks ago and feel sorry your problem has not been solved.
I read a bit on cavitation -topic unfamiliar to me - and came through the article one of our forum user suggested you.
did you go to : http://cav2003.me.es.osaka-u.ac.jp/C...3-OS-1-004.pdf ?
Particularly they are mentionning far field boundary conditions at upstream and downstream boundaries have you tried them?
let me know if this helps
hope your problem will be solved soon
David
Old   March 30, 2004, 12:18
Tania
Thanks a lot for your answer.
According to fluent documentation, the farfield bc are used for compressible flow.
And in my case it is uncompressible flow and it is without the cavitation model. Of course my aim is to use the cavitation model but I have to solve this problem first....but it seems complicated !!!!
I have been struggling with this problem for many days. I tried sooooooooooooo many things but they didn't help.
Old   March 30, 2004, 12:33
David
ok, you've tried with 3 m/s and 1 m/s. have you increased gradually from 3 to 8 m/s to see how it goes? from which velocity do you get the negative value?
i believe whatever small it is there will be compression at the leading edge of your plate right? have you read the article?
have you tried with farfield BC anyway? farfield works for compressible flow but i believe you can try it in your case. incompressible flow is just a condition of compressible flow with so you can apply this condition i believe.
dont give up, i'm sure your problem will be solved soon!
David
Old   March 30, 2004, 12:59
Tania
Actually, I increased the velocity slowly from 1m/s to 8 m/s. everything seems fine only for 8m/s where I get negative absolute pressure.
What do you mean by "whatever small it is there will be compression at the leading edge of your plate"
Concerning the article, I read other articles from Cav2003. And I 'll try the farfield Bc and see what happens.
Old   March 30, 2004, 13:10
michal
I had similar problem in case of natural convection. I had a very small velocities (V=0.02 m/s) In my case I changed the reference pressure location to X=0, Y=0. It helped.
michal
Old   March 30, 2004, 13:32
David
i meant there will be a compression anyway at the leading edge of your plate.
let me know what happens with farfield BC
ensure your operating pressure location as Michal mentionned
David
Old   March 30, 2004, 16:37
Tania
thanks, I'll tell you the results
Old   March 30, 2004, 19:41
Otilia
The only way (I can think of) you can get negative absolute pressure is if the operating pressure - reference pressure has been changed from the default value of 101325Pa and your reference location is bad positioned. Check that and I am pretty sure you will solve the problem.
negative pressure in cfx flar.t CFX 1 December 19, 2006 00:20
negative static pressure Selo melo FLUENT 5 December 18, 2006 10:30
NEGATIVE ABSOLUTE PRESSURE IN FLUENT vitmalin FLUENT 0 September 29, 2006 00:48
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
negative pressure mAx FLUENT 0 January 25, 2006 15:31
