Dynamic mesh model setting?
Old   March 29, 2004, 01:34
Default Dynamic mesh model setting?
David
Fluent prompts:"By default, spring-based smoothing on non-triangular or non-tetrahedral cell zones are turned off. If you want to use spring-based smoothing on all cell shapes, you can turn on the model for these zones using the text-interface command spring-on-all-shapes? in the dynamic-mesh-menu."
But the fllowing error occurs when I input the command "spring-on-all-shapes".
/define/models/dynamic-mesh-controls> spring-on-all-shapes
Error: eval: unbound variable Error Object: help
Old   March 30, 2004, 00:45
Default Re: Dynamic mesh model setting?
Pat
I'm not sure what the problem is, but you may need to create an interface at certain boundaries.
Old   March 30, 2004, 10:11
David
I use dynamic mesh model to simulate a FSI problem, and the user-defined motion type was adopted based UDF. I found the spring-based mesh motion method did not work when structural mesh or mixed mesh with structural boundary layer mesh was used, so I want to activated the function"spring-all-shapes" through text command according to Fluent Guide. But the above problem occured.
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 11:42
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
problem of dynamic mesh for a piston model pipin Fluent UDF and Scheme Programming 2 August 2, 2010 15:35
about dynamic mesh model lingo FLUENT 0 August 2, 2004 22:43
