VOF SURFACE TENSION EFFECTS
Old   March 26, 2004, 04:36
Default VOF SURFACE TENSION EFFECTS
ozgur
I am able to get the expected inner and outer velocity fields for a free falling water drop in supercritical CO2 having diameters ~4mm, Re~7000 using 2D Axisymmetric VOF. But the fields for lower diameter drops (~2mm, Re~2000) especially with higher surface tension values shows very disordered velocity fields (I would expect 2 wakes inside, and 2 at outside the drop, but what I get is flow is seperated at degrees higher than 90°, there are many wakes in and out the drop) Is that a weakness of VOF under strong surface tension effects, or somethign with the problem set up can solve the problem? (I have tried 3D VOF without axisymmetry, that also did not give the proper fields)
Regards
VOF method +surface tension yapalparvi OpenFOAM Running, Solving & CFD 5 July 17, 2009 04:56
two phase flow with surface tension qunwuhe@hotmail.com Main CFD Forum 2 October 21, 2007 01:29
Inconstant Surface Tension on Interface in VOF Atieh CFX 4 February 10, 2007 16:47
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 10:57
UDF macro for surface tension coefficient Frederik FLUENT 2 May 30, 2005 11:54
