HELP TIME STEP!!
Old   March 21, 2004, 16:30
Default HELP TIME STEP!!
merry
Hello
I am computing an unsteady flow around an obstacle in fluent 6.1. First, I made computations with the steady case. And then when the solution converged I turn on the unsteady case.
I calculated the time step ( time step = T/100= 1.e-3 s) from the strouhal number that gives the shedding frequency (f= 1/T)of the vortex.
The problem, when I started the computations with this time step the solution converged after the 1st iteration. So, I increased the time step (1.e-2) but still the solution is converging after the 1st iteration. and then I increased the time step again and again and again.... every time the solution is converging after the 1st iteration. So, I really don't know what fluent is doing ???? it seems that for any time step the solution is converging.
Can someone explain what is really happening???
thanks
Merry
Old   March 25, 2004, 14:35
Default Re: HELP TIME STEP!!
Zhihua
I think you can change the convergence criteria in Fluent. It is located at Solve-Monitor. Set a much lower value for convergence of any equations.
Old   March 25, 2004, 15:38
merry
thanks a lot for your suggestion. I'll try that!
HELP! time step too small? meangreen Main CFD Forum 6 May 31, 2018 11:41
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 23:50
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
