Central Differencing Scheme in Fluent
Old   March 19, 2004, 04:35
Default Central Differencing Scheme in Fluent
alice
I used the text command : solve/set/discretization-scheme/mom 3. mom representing momentum, and 3 is the value given for the central differencing scheme. my model does not use large eddie simulation. the manual however says central differencing is only available for LES, but i get a solution which converges differently from the default 1st order upwind scheme. Could it be that Central differencing is available for other models?
Old   March 19, 2004, 09:05
Default Re: Central Differencing Scheme in Fluent
Melih GULEREN
As I know, this scheme is only used for LES and DNS. And for LES, it is strongly advised to use the scheme rather then 1st,2nd or QUICK shemes.
Regards
Old   March 21, 2004, 08:30
mystic_cfd
Hi Alice
You have successfully activated the central-differencing (CD) by using the text interface. Fluent recommends CD for LES and DNS, and it is not possible to activate the model using the GUI (graphics interface) unless you also activate LES in the GUI.
Just be careful when going back to the GUI for settings of the solver. In some cases Fluent complains that you should not be using the CD option without LES and will then automatically re-activate 1st order differencing. Always check that the scheme you want is active by running solve/set/discretization-scheme/mom before starting further iterations.
Enjoy the fairest Cape and may the convergence be with you.
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
MARS differencing scheme Bart Siemens 4 January 27, 2005 10:43
Challenge of differencing scheme choice Julie Polyakh Siemens 2 July 30, 2003 12:12
Differencing scheme for k-eps model Ron Barer Main CFD Forum 14 November 2, 2000 01:02
Scheme and Fluent UDF? Arthur Valais FLUENT 11 January 31, 2000 14:19
