March 17, 2004, 10:54 |
Pressure outlet condition?
I give this pair of inlet & outle boundary conditions, that velocity inlet and pressure outlet, in my case of simulating imcompressible flow of wind tunnel test. I am not sure this two problems:
Could both the operating pressure and the gauge pressure at outlet be set to zero? And how to set the backflow k & epsilon? Just the same as the inlet ones,and how it effect the results? thanks. |
March 18, 2004, 01:26 |
Re: Pressure outlet condition?
Further to David's question, I need to know whether I can set operating conditions at different x & y coordinates? Please let me know if the outlet/ inlet pressure need to be set by "Operating Conditions" or at the time of initializing the solution? Thanks
March 19, 2004, 03:16 |
I know "0" of gauge pressure at outlet means no pressure difference from operating pressure is. If you use 760torr as operating pressure, "0" of gauge pressure at outlet means pressure at outlet is same pressure as operating pressure. If operating presure is "0", pressure effect of flow will not be considered. So, this condition is improper for your model, you may need to change BC for outlet from pressure outlet to outflow. K and e at outlet is depending on your model. If your outlet is far from domain so that flow at this region is stable, and if there is no turbulence, use very small value such as 0.001. Thanks,
March 19, 2004, 05:40 |
Ryu, My question is still unanswered. please advise! Thanks
simple model, difficult outlet | Eric | CFX | 7 | May 23, 2014 09:13 |
Static pressure boundary condition at outlet | jennz | CFX | 4 | February 11, 2014 04:29 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 04:23 |
Using pressure outlet BC | Shreyansh | FLUENT | 0 | November 5, 2010 15:57 |
Natural Convection (Operating Pressure condition) | Andrew Tress | FLUENT | 1 | July 3, 2006 19:27 |
