March 17, 2004, 09:39 |
How to define Epsilon in RSM model?
I want to use RSM model to simulate wind tunnel test of buildings. There are some different ways to give epsilon: one is like epsilon=Cu^0.5*k(z)*du/dz(based turbulence equilibrium hypothesis of standard k-epsilon model);
the other is like the style epsilon=Cu^0.75*k^1.5/(Karman Constant*L) or epsilon=Cu^0.75*k^1.5/(Karman Constant*z), Also fluent suggest give epsilon as epsilon=delta(k)*u/Lx in the case of simulating wind tunnel test. So,I am not sure how to give epsilon properly and how it effets the results. Any suggestion will be great appreciated. |
Epsilon boundary condition for walls in LamBremhorst LowRe model | maruthamuthu_venkatraman | OpenFOAM | 1 | April 21, 2019 06:25 |
How to set up BCs for k epsilon model | Julian K. | OpenFOAM Pre-Processing | 44 | October 26, 2015 09:23 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
