Premixed combustion -Laminar finite rate model
Old   March 16, 2004, 17:39
Default Premixed combustion -Laminar finite rate model
Shankar
To model pre-mixed combustion, has anybody used the laminar finite rate model?
I have a few questions about this. Id appreciate it very much if anybody could help me out on this.
Thanks and Regards, Shankar.
Old   March 16, 2004, 18:10
Default Re: Premixed combustion -Laminar finite rate model
cg
What are your questions?
Old   March 16, 2004, 18:19
Shankar
Hi
What will be the unit of A when E is in j/kg mol and other values are in SI units? ( k= A T^n exp (-E/RT) )
If you used the default reactions from the FLUENT database, do you have any idea how A and E were calculated?
I also do not understand how the value of the rate exponent was set?
Most of the literature found have the units of A and E as cm3 mol s and kJ/mol. Did you define your own reactions?
Thanks, Shankar.
Old   March 16, 2004, 23:03
cg
: mol and other values are in SI units?
The units of A depend on the reaction: the Arrhenius reaction rate is governed by the product of the species concentrations to certain powers. So, the units of A are different for each reaction.
When converting from cgs units (eg CHEMKIN) to SI (eg Fluent), you can use
A(SI) = A(cgs) * 0.001^(sum_exp-1)
where sum_exo is the sum of the rate exponents
: the FLUENT database, do you have any idea
: how A and E were calculated?
Most of these came from:
Westbrook, C.K. and Dryer F.L., (1981) "Simplified Reaction Mechanisms for the Oxidation of Hydrocarbon Fuels in Flames" CST, 27, pp.31-43
: of A and E as cm3 mol s and kJ/mol. Did you
: define your own reactions?
Fluent can import mechanisms in Chemkin format.
Old   March 17, 2004, 16:32
Shankar
Thanks for your reply. I will go through your references.
Shankar.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Turbulent premixed combustion error... XiFoam model achinta OpenFOAM 1 June 23, 2010 06:45
Combustion in a flame premixed & laminar Quasimodo FLUENT 0 December 5, 2007 09:06
Help about premixed combustion with BVM model Nena CFX 1 September 8, 2007 11:15
unsteady laminar premixed combustion seaspace Main CFD Forum 0 August 6, 2002 00:21
