Drag Coefficient
Old   March 15, 2004, 14:27
Default Drag Coefficient
António Nery
Hello!
How can I determinate the aerodynamics coefficients(drag and lift) in a two-dimensional and three-dimensional body in Fluent 6.0?
Cheers
António Nery
Old   March 15, 2004, 17:57
Default Re: Drag Coefficient
mike
In the menu Solve>Monitors>Force... you can select what coefficients do you want to report and how to do it: in the screen, in a file (with the name specificated where "c.-history" is showed), in a graphic, or combined.
Old   March 16, 2004, 04:37
mateus
Hi!
If you want just the converged values go to the "report-forces" and print them.
best regards
MATEUS
Old   March 30, 2004, 11:03
Jason
I also used the same way like toutorial to slove the external flow of truck. But I can'nt get the right answer about drag coefficient (Cd<1). My case is 3d and unstructure mesh. Finally I got Cd using custom field function. I can'nt make sure that this is a right answer.
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 10:22
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 01:49
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 13:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
