March 11, 2004, 20:28 |
Discrete Phase Model
Hi All,
Is there any way to specify the number of parcels FLUENT inject at each timestep? Thanks Shane |
March 12, 2004, 13:19 |
Re: Discrete Phase Model
Hello, the flow rate you are gonna fix will give you the number of parcels injected in your domain, knowing the parcel density of course.
thomas |
March 14, 2004, 19:40 |
Thomas,
Thanks for you reply. This was what I expected but has not been the case so far. Changing the flowrate hasn't changed the number of particles injected. At any given flowrate, 272 particles are injected per time step. This happen even if the number of particles per parcel is less than one. Do you have any other ideas to why this might be. Thanks Shane |
March 15, 2004, 17:07 |
Hi, Shane If you are using turbulence model, you may specify the number of tries in DPM->injection->turbulence dispersion->stochastic model->number of tries. I guess your release plane has exactly 272 facets. You can see it by surface->plane->manage. If that's the case, the final number tracted would be 272*#of tries. An alternative way is to refine the region where you release the particles so that you can have more facets. Hope it helps.
Jun |
March 15, 2004, 21:22 |
Thanks Jun,
My release plane does have 272 facets. I will try to refine it and see how things go. Shane |
Discrete Phase Model (bubbles stuck in an eddy) | sahraaan | FLUENT | 0 | September 8, 2011 01:32 |
Discrete phase model -FLUENT | s567d | Main CFD Forum | 0 | March 15, 2011 07:36 |
Discrete Phase Model - URGENT!! | KS | FLUENT | 0 | October 29, 2008 13:19 |
please (discrete phase model) | bharathi | FLUENT | 0 | July 13, 2006 12:41 |
discrete phase model with reaction | Art | FLUENT | 0 | September 7, 2004 11:51 |
