how to pass bc from one zone to second zone
Old   March 8, 2004, 06:28
Default how to pass bc from one zone to second zone
Maria
Hi
Anyone help me to solve this problem.
I have two volume zones name as A & B.I know bc at A inlet and B outlet. I want to solve A & B zone togather by starting with A ( applying known inlet and assume outlet bc for A).
After computing only A zone i am looking to take average of all of velocity components and looking to apply this as inlet bc for zone B.
Now I would simulate zone B with this calculated velocity components as inlet bc and known outlet bc.
After computing zone B, average of pressure at zone B inlet would be bc for zone A outlet for next calculation of zone A
This iterative process is repeated until pressure on the A outlet and B inlet is unchanged.
Thanks in advance
Old   March 15, 2004, 01:31
Default Re: how to pass bc from one zone to second zone
S.B.SHIN
Hi. I think that you can approach this problem easily if you used scheme language. try scheme!
Old   March 16, 2004, 00:12
Maria
Dear Sir
I don't know anything about scheme language. I am using Fluent. At outlet of a volume zone surface I have 30 horizontal and 20 vertical lines grid. So every horizontal line has 20 nodes. I am looking to take mean of these 20 nodes at each horizontal line. so I get 30 means.
At inlet surface of second volume zone I also have 30 horizontal and 20 vertical lines. Similarly at every horizontal line I have 20 nodes. At every (20) node of first horizontal line of second volume zone inlet, I want to apply mean value of first horizontal line of outlet of first volume. Similarly at all 30 horizontal lines of second zone inlet I want to apply means of first zone outlet.
May you please tell me that which define macro in Fluent UDF could help me to solve this problem?
Thanks Maria
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
