March 4, 2004, 04:37 |
Problem in calculating drag coefficient
I am a beginner in using Fluent. Please help me out to calculate the drag and friction coefficients over an aerodynamic body, if I have the results of pressure, temperature and velocity profiles.
March 4, 2004, 12:55 |
Re: Problem in calculating drag coefficient
Well its not difficult:
go to report-forces and give the direction vector...for example give 1 for x and 0 for y and 0 for z (3d)....that will be axial force. Similarly x=0, y=1 and z=0 is Normal force.... In this way for Lift and drag for a body at 10 deg AOA give components as x= cos(10)n y=sin(10). fluent will automatically report the forces and moments for you. I hope this solves your problem Further you might find it helpful to look at the 2nd tutorial in fluent which is modelling external compressible flow on an aerofoil.. Regards Farooq |
March 18, 2004, 01:40 |
Thanks Farooq! Can u please help me in defining boundary conditions in a duct flow?
Currently I am defining Inlet Static Temp and Inlet velocity. No condition defined at the outlet boundary. Also, where should I define Inlet Pressure? Does it have to be defined as "Operating Condition", giving the x & y coordinates of the location (inlet / outlet etc.) or it should be defined in " Boundary Conditions", or while I initialize the problem? Also, please advise whether the solution has to be 'computed from' Inlet Velocity Zone or from 'All Zones'? Please help! Thanks |
Drag Coefficient for Ellipse Form (2D) | Ketut Utama | Main CFD Forum | 8 | December 11, 2014 12:03 |
coefficient drag | JEHERZ | CFX | 5 | February 9, 2012 07:28 |
lift and drag ceofficient problem | icemaniac178 | CFX | 6 | August 17, 2011 19:40 |
Solidification drag coefficient | atulverma | FLOW-3D | 1 | May 14, 2009 10:24 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
