Fluent error in periodic PDF combustion cases??
Old   March 2, 2004, 17:41
Default Fluent error in periodic PDF combustion cases??
George
Hi everybody,
I recently tried to simulate my NG combustion case on a rotationally periodic grid. With the Magnussen-Hjertager model I get relatively good results, so I'd like to compare them with assumed PDF model and laminar flamelet model. But I get unrealistic (low) temperature profiles around the rotationally periodic faces. Did somebody of you get into this kind of trouble or otherwise has a positive experience?
Thanks, George
Old   March 4, 2004, 08:48
Default The Fluent error is located
George
I just want to let you know I found the reason for the physically incorrect behaviour. It was coused by "node-based" gradient calculation option in the "Solver" panel. When I switch to the older cell-based method, the error vanishes. So there must be an error in the implementation of the node-based gradient calculation, which however has effect only in certain circumstances.
good luck G.
Old   March 8, 2004, 17:45
shankar
hi , this is shankar, i have done modeling using gambit and when iam trying to read the mesh in fluent6, fluent gives some error. It says - no cells in zone id=0, ind1=1 and ind n=0 i donno what that means. i have tried many ways modeling and trying to read in fluent. but the same error always shows up.
If any one knows some thing about this,please give me an email . i would be very much thankful.
shankar.
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 29, 2010 00:32
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
Combustion SImulation in Fluent santhosh1987 FLUENT 1 May 14, 2010 17:03
Coal combustion with Fluent 4.5 or 5.0! Sriram Popuri Main CFD Forum 2 July 24, 1999 12:34
internal combustion engines with FLUENT Elizabet Main CFD Forum 1 April 14, 1999 14:10
